64Herald
Been there, done that, now whats next?
Selden,Long Island,New York
2006 Rocket Classic Bone/ivory
This winter I want to adj my valves. Big job or not? is it the Suzuki shim kit I should get? I used adj valves with the adj nut. never with shims the dealer says about $500-$700 for the job
This winter I want to adj my valves. Big job or not? is it the Suzuki shim kit I should get? I used adj valves with the adj nut. never with shims the dealer says about $500-$700 for the job[/QUOT
I would be liiking for another dealer, Last may i took mine to the dealer, they adjusted the valves, changed the antifreeze, greased the splines, changed the diferential oil and i don't remember what else, the bill was $535 for the whole thing:)
They quoted me around $300 just for the valves,
This a short write up from the first time I did it.
http://www.r3owners.net/general-tech-talk/3712-i-checked-my-valves-today.html
Not too long after that I ended up putting new cams in and had to reshim it. If you find out that you are going to have to swap shims, I would get the Triumph cam jig or see if your dealer will loan/rent it to you. You will also need a set of calipers to measure the shims with. I would hold off on buying the kit. You might be able to swap some around and end up only having to buy a few.
+1 ... That sounds more like the price for the entire 10K service if it should require valve clearance adjustment.
More often than not, a valve adjustment isn't even required and the price is lower even though you are still paying the labor for removing the valve cover.
My valves were inside specified clearances but the fools didn't replace the VC gasket. Make **** sure you or the dealer replaces the gasket rather than just re-torquing it. Mine split wide open one year later and made a big **** mess.
If I had it to do over again, I would have just done the 10k myself (done every service since) and checked the clearances myself. If it had required any adjustment I would have thrown it back together and taken it in for just the valve adjustment since I don't feel like messing with shims 50 miles from a dealer/parts. If I'd have done it that way, I would have saved a bunch of money and known for sure it was put back correctly with new gaskets. But at that time I was gainfully employed with money to burn and little spare time. 20/20 hind sight is a ***** ain't it?
