Vacuum hose routing
Get a torch and check the rubber throttle body to head adaptors and clamps. Ideally take throttle body completly off and clean, remove injectors and clean. Also remove throttle body to head adaptors and replace the orings on the surface that mates to the head.
i see u have changed your fuel filter.
i do not know where u r at now because your last post was Friday. if u have not started on the injectors u might want to try the starter fluid a couple of times to see what happens. may be it u can get some new gas into the injectors it might clean it up. if i was working on it i would want to put a fuel pressure gauge and measure the pressure on it however u might have a prob with cost or availability.
it seems that u have a limited mechanical ability so u might consider a good bike shop. if u do pull the injectors i would take them to a professional to have them cleaned.
when the bike starts can u get it to rev a little? may be will rev if u try the starting fluid and then see if it will rev? hth
Well, I finally have good news. The bike is running.....and quite well. Before attempting to clean the injectors, I took the advice of trying to get some fresh gas running into the system. So with new gas, some ethanol/injector treatment, and a lot of turning over, it finally runs! Seems like it was just sludge in the filter and old gas, even though there was stabilizer in it. I did and ISCV reset and loaded a new map from HansO as well. Thank you to each and every one of you that helped me along the way. My sincere apologies if I was a pain in the ass.
On the list for this winter:
Headlight relay kit from Decosse
Ramair kit
New tires
Rear brake rotor
Led headlights
Flyscreen
Full exhaust (if I can afford it. At minimum, a slip-on for now)
Suspension (Hagon Nitros or Progressive 430's)
New speedo & tach
Happy riding, boys.
