REGULATOR
Turbocharged
I'm not too sure how much the D&D's lean out the AF...
I know the triple K&N's will however lean it out considerably. ( More air)
the conservative answer is wait till you have Tuneboy.
BUT I know the feelign your going through. it might take 2 weeks to get your tuneboy, and then you will need to get your "KEY" to unlock it, which might take a bit longer depending. I think I got mine via email in 24-48 hours after using the tuneboy cable to download the ecu number and email it in.
I once installed a set of jardines without the airfilters and tuneboy while I waited.. it was definitly not running right.. was'nt tuned properly.
smelled funny and popped and crackled and backfired constantly
and I was hesitant to give it full throttle or ride it too hard.. so I stopped finished the filters and then waitind for tuneboy
you might be ok with just the D&D's since they are more or less slip ons with a cat delete, but Id wait to do the trip filters until tuneboy..
you could always do it all and not ride it, but I know that you wont be able to resist..
