Thanks for the information. One more question: I'm installing signal mirrors and kury bullet lights. Will I need a load equalizer for each light? Thanks.
Guys
Forget the Load Equalizers!
Nothing but a resistor to earth that creates heat.
This bike runs hot enough.
You need a NO LOAD flasher unit. One I have coming in is from http://autolumination.com/
The stuff from auto stores are variable load etc and may not work unless you have some real powerful LED's.
Check the pin out for the right one. Just plug and play.$18shipped
ps I previously bought the tower flashing tail light replacement and the little blue bulbs that fit in the headllight assembly. $25 here
Just got my NO LOAD flasher in from http://autolumination.com/ and it works just as intended. The minimum current draw is 0.02 A to 20 A so you can mix and match as you wish and it will work. It is the 35,36 unit or specifically the CF13 GL-02 . I have 4 lights installed that draw 0.2 A for each side when flashing. Pretty good I believe. I also have the varistor to protect them from voltage spikes- haven't wired in yet. Plenty room for more light now and maybe a heated seat
The brackets on the front are from Custom Chrome, springer soft tail relocation brackets, just right.
