Could I use the cat eliminator for the standard R2 Classic? Does it look like that? I figured the crossover looked a little weird. Maybe why it's so quiet, even with the TORs.
I can tell you right now, the numbers I'm going to see are going to be lower than triumph states. There numbers are at the crank. My numbers will be where it counts, the rear tire. Heard of RWHP? When I get thru, I'll beat the HP rating Triumph posts at the rear wheel, not crank.
I'll be thru breaking her in this weekend and get the syn oil in her. Then we'll get started. Gotta get a few things worked out first. Need to the pipes right, then look at the triple Kand N setup. **** I wish I could get a set of those 3 into 1 Preds from Sam.
Later
