reinie
.040 Over
My OEM Mettzlers are finally about worn out. I have almost 12,500 miles on my front tire (very little tread left in the center part) and just a bit more tread left on the rear which has about 10,000 miles (the original picked up a nail at about 2500 miles and needed to be replaced). I went shopping around online and found that Michelin Commander II tires are supposed to get nearly 25,000 miles of tread life. They are a bias ply reinforced tire. Only thing is that the size match for the front tire of the R3T is a rear application tire in the Michelin Commander. Also the rear tire is a bit different in that it's a 180/65 B16 whereas the stock R3T tire is a 180/70 R16. I imagine the outside diameter will be a little bit less on the Michelin but that shouldn't affect much other than the speedometer/odometer readings slightly. The pricing of the Michelins is a little bit lower than the Metzlers and Avon Cobras but not much. But if I can get double the tread wear out of them it would be well worth it.
