Tire mounting delima
rusty
Turbocharged
Northwest, MO.
2005 Rocket III
Hey everyone, I've done some intense searching for the best price on a rear tire (went with Metzler again) and scored one for $193.00 with free shipping.
Not too bad I'd guess but here's the problem. None of the bike shops in town will mount the tire for me due to insurance reasons. They will only mount a tire purchased through them. So, I did my best to save $$$$ but now I'm in this situation.
Anyone else go through this? I'm certain I can't tackle it myself, unless I wouldn't mind how the rear aluminum wheel looks when complete, needing to use pry-bars & a BMFH. Not even sure I can do the job at all. Captains have stated that even shop mechanics are challenged by these tires.
???:confused:???
Drat & dad-burn.
Paul Hyland
Turbocharged
League City TX
UM
Insurance reasons??/:confused:. If it came from Metz it is the same place they would get it.
Don't go to a dealer try a motorcycle shop that doe's eveything. I have a place down here called X-it cycle that has a machine to do big tires and the guied dosn't even touch the rim (no marks)
busajack
Top Fuel
Cheyenne
mounting
Rusty you can also try tire shops that mount the 18s -22 inchers for the kids now a days..The new machines are more capable.. Jack
Sidecar Flip
Rusty:
That smacks of what I was told by the Triumph tech at castle Powersports when I asked them if they had a rubber washer and could I use a metric hex key. As soon as they found out what I wanted to do the answer was no, 'for liability reasons' even though they would not touch Raymond's bike at all, just me and with Raymond's permission. Of course they wanted to sell Raymond a Throttle Meister on the spot. No liability either real or perceived there. Problem was, they weren't getting the profit with my fix. Neither was I. I just wanted Raymond not to suffer wrist cramps or numb fingers on the way home. You fully well know about liability issues and trade dress because you and I discussed it, however, it seem to me as though the liability thing becomes a catch all when a shop don't want to do something that they are making a minimal profit on.
It's too bad you don't live around here. I have a good friend that owns a motorcycle repair shop that services all makes and he has a Snap-On tire machine that don't touch the rim either. Even though he sells tires he told me that whatever tire I bought, whether from him or elsewhere, he'd mount and spin balance it.
I'd run, not walk away from that tire shop and then bad mouth them to everyone. That's just good business practice on our parts.
You could mount it yourself. You'll have a ***** of a time dismounting the old one. I'd do what Gunshots did and cut it off. A die grinder and cut-off wheels should make pretty short work of the tire just be careful when cutting the bead cords and wear a particulate face mask. Mounting a new one will painful too but you could do it, I'm sure. If I can mount tractor tires myself, you can do a bike tire. Use plenty of lube (I use liquid dish soap in water) and good tire spoons (believe it or not, TSC sells top of the line tire spoons and bars) but they aren't cheap. You'll still have to get it computer balanced but before you do, make sure you pull the adhesive weights.
You don't need a BMFH to break the bead. You need no hammer at all. Only truck tires need a tire sledge or a tractor tire that has a really stiff sidewall. get yourself some good "C" clamps that have enough throat and depth to engage the tire at the bead, pull the valve core and crank those puppies down on the tire. They will pop the bead right off the rim and then use the spoons to lever it off the rim to one side. Stand the tire and rim vertically and then lever the other side off the rim on the same side as the first bead came off from. That is, if you don't cut it off. Another good trick is to lay the rim and tire down on a sheet of plywood and carefully engage the tire as close to the rim as possible with your front tire on your car or pickup truck. That will break it from the rim too. Just be sure to pull the valve core. Once you get the tire off the rim, be sure to turn the valve stem around the other way so it's easier to fill. I used to sledge tires on trucks and tractors but I went out and bought a Bead Cheeta which is basically like a can opener that's driven with a 1/2" impact wrench. The sledge is an ornament in the garage now.
Good luck. Actually it won't take any luck, just some good tools and a little time.
If you were here, I'd do it for ya. Plus, I'd install a FlipMeister, all for no charge. After all, that's what friends are for.
wilbur-t
Top Fuel
Carthage N.C. U.S.A.
I mount mine on an old car tire machine. I have to pull the first bead up with a tire spoon and then use a die grinder with a cut-off wheel to cut the bead. [Cut it right on top of the spoon, so you can't slip and get your rim.] After that it's pretty straight forward. Line the red dot up with your valve stem when squeezing the new one on. I never balance my rear tires, only the front. Never felt any vibration from the rear.
busajack
Top Fuel
Cheyenne
Mounting
Hey Flip when you do this with your own please take picts and post them..Ha Ha Don't take off the ballance weights and put the new tire In exactly the same place..No ballance needed.. Jack
Toystoretom
I'll mount it for you on any Saturday morning if you will bring me the rear wheel removed from the bike and let me know just a few days in advance. I'll do it at the shop, I have a tire machine that will mount Z rated 40 series 18 inch car tires... I think it can handle one whimpy little Metzler. We might even be able t use the spin balancer.
Just let me know...
BTW... you will have to drive to Blue Springs to do it :eek::eek::eek:
Toystoretom
The last time someone sent me motorsickle parts the crack pipe fell out of his shirt pocket as he bent over to seal up the box. I called him up and asked him what this goofy looking thing was in the box and he said to just send it back... he'd been looking all over the place for it.
"Only users loose drugs."
