ThePhoinix
.060 Over
- Joined
- Nov 10, 2016
- Messages
- 196
After about an hour of very pleasant riding I noticed that whenever I released the throttle to start to decelerate there would be a jerk rearwards, and when applying throttle from zero there would be a jerk forwards. This was in all gears, but not when shifting it seemed. Then I stalled at around 30mph, restarted easily enough and kept on enough throttle to keep it from happening too many more times. Of note is that this had NOT been the typical behavior before now.
I hoped it must be a throttle problem, and then I noticed there was zero freeplay in the twist. loosened up the throttle cable nuts all the way and now it seems I'm at around 2mm freeplay. (2-3mm is the recommendation)
Does this seem consistent with throttle cables that are too tight? Or is something else going on I need to track back to the throttle bodies, or something else completely?
This is still a new bike, 2015 r3t with 1500 miles...
I haven't taken it back out yet, and wanted to check to see if there's some dire issue I should beware of.
Thanks
Thanks
