TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
Wow, that must be unfused, my whole house AC only has a 50 amp fuse, I can't picture a 200 amp fuse on a motorcycle
they are not fused
the starter solenoid takes most of the abuse the solenoid washer looks like it was copper welded from the sparks.
that is why you need a larger positive cable to flow the amps so if you didn't have a starter you bat cable would be very small.
fastfun
Netherlands
triumph roadster supercharged, 2010
You
they are not fused
You mean 'thicker' with 'larger' positive cable ?
next, a more powerful starter does need a thicker positive cable you think ?
Tripps
Retired superhero
Florida and NY
R3T,Sprintona,K1200GT, Blackbird,r/65 hack
If I remember, it's the ground that's the weak link, when I upgraded my starter, I put in a heavier ground wire.
TURBO200R4
TUCSON AZ
You
I am not good at explaining so will try again.
On the battery cables they need to be thick to flow the current/amps but the rest of the bike electrical system is less than 30 amps and is fused with a 30 amp fuse.
On my bike i think that the negative cable was going bad so i just added another cable to it and that helped a lot.
When I upgraded my starter i never gave it a thought (until your post) lol
It works real good and might work even better with a better positive cable.
