Kevin frazier
Widowmaker!
Nashville
2008 Triumph rocket 3 touring
I purchased a 2011 speedometer and ecm off a 2011 rocket touring with 11000 miles from penwalls and did not need, problem fall detection switch. Anybody interested in these items
Wow, wish I would have seen this earlier. I just bought a speedo from Pinwalls. But the speedo, odometer, fuel gauge and signal canceling switch are not working. They have a video of it working on the bike it came off. I'll need to look into that fall detection switch, how did you discover that that was the issue? Did you need to replace or reset it? If I end up needing the ecm I'll be sure to contact you.
Thank you,
Thank you,
For me the road speed switch on the bottom of the ignition was culprit, fixed all the speedometer cluster issues, speed self cancelling blinkers
Thank you,
Be aware that the speedos from 2009 and before are very different from 2010 onwards. They are not cross compatible. A pre 2009 can however be fitted with aftermarket speedos - Post 2010 CANBUS bikes cannot. The touring is different again.
