kcc11
- Joined
- Jul 4, 2008
- Messages
- 294
- Location
- Cypress Texas
- Ride
- 2005 Rocket III Std & 2012 R3R with 240 Carp. kit
Have 2005 planejane Rocket with 53000 miles. D&D exhaust, K&N's and tuneboy.
Lost speedo last ride. Also lost the warning lights and speedo and tech sweep when turned on. Also had code 1500, vss problem. Tested vss and seems fine. Tested wiring per service manual. Did the update on the wiring for gauges. They tested good but had the new connector. If one of the connectors are unplugged from the ecu then everything works fine but the speedo sweep. With everything connected using Tuneboy and the testing the tech, again everything but the speedo. I have checked and a number of people have had the same problem but no one has posted back a fix. I'm 95% sure is the speedo, but. I even took the speedo apart and it looks o.k. The ignition switch is working fine for now. Have plans to replace or go keyless not sure yet. Any help is appreciated. If anyone has a good one lying around let me know.
