Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
UPDATE:
Mufasa is fixed.
The short version: Circlip was out of place, 2 gears tried to engage at the same time, bad things happened.
Read on, for a swervy, curvy, roundabout thread that follows my repair and some upgrades along the way. With quite a few pics.
Scenario:
Riding up hill about 4000 RPM in 3rd, 30-40% throttle, kick the shifter to go to 4th, false neutral. Pull clutch try again, false neutral + grinding + no drive force.
Pull off, kill bike, fight with lever by hand because it’s stuck. Get it to 2nd and try to baby it home. Try 1st, 2nd, 3rd, 4th all work try for 5th does a repeat with a stuck shift lever buy not in gear.
Get it eventually to go back into 2nd and get it home without shifting anymore. As I’m pulling into my driveway I hear a grinding sound from he clutch area when I pull the clutch.
@Sam had a very similar failure, almost to a T back in 2015 at almost identical power level 240hp/180tq.
Bikes not going back together until I find the cause and figure out a permanent fix.
Point of clarification:
I do not, in any way, believe this was an assembly error while at Carpenter Racing, I take full credit and honors for munching this transmission.
Mufasa is fixed.
Scenario:
