9Ball
I'm getting ready to take my '07 R3 to the dealer next week for some warranty work and wanted to get some feedback from the forum.
Has anyone here had a problem with the shifter not returning? It appears that the return spring on mine is either weak, broken, or there's something interfering with the shifter shaft/pedal. In order to shift I need to manually lift or press down on the shifter pedal with my toe in order to find the next gear. This is most problematic for 4th and 5th gears, especially on the upshift. I disconnected the shift linkage from the pedal and the pedal moves very freely, so it's definitely internal to the engine casing.
Any feedback is welcome, but anyone having the same problem might share the results of the fix including how long the bike was in the shop and whether Triumph gave any problems covering the fix.
John
John
