Kevin frazier
Widowmaker!
Nashville
2008 Triumph rocket 3 touring
what is the proper way to adjust idle, in my case I need to raise it I’m at 850 and I would like 960 to 1000. I do not have a stepper motor or 2nd throttle. The cables are adjusted with the required free play. A picture If you could please. Thanks
I see your still waiting on the answer. So while your waiting. I'm currious why if you do not need the stepper motor, does it cycle when you just turn the key on?
I’m still waiting but I only asked last night and I’ve perfected patience this winter. I don’t know why it cycles if you don’t need it.
I have done it with the pull cable last year but it only leaves about 1mm of free play on cable. Once the idle is set it doesn’t change, about 60 seconds of staying with throttle after you fire it up and she idles exactly where it’s set. The infamous idle screw would be my guess, at this point since I went and removed everything, I like it, ole Skool
your curious, lol, i am aware you do not like the throw it in the drawer stepper motor upgrade and I am very aware you know the answer to the question you are curious about. curious drag gone nuclear fixer curious, heathen more like it
