I actually removed all three injectors from the throttle bodies and attached a clear plastic hose to each to observe the fuel flow. All three injectors fired at the same time and seem to inject at the same pulse length (although impossible to measure exact pulse length with naked eye). I'm guessing Triumph doesn't bother with the sophistication required to adjust different pulses for each cylinder and simply has them all fire the same pulse length at the same time. If you are worried about the rich condition, you can swap #1 injector with #2 injector, clean the header flange, run it awhile and check to see if the rich condition moves to cylinder 2. Or if you have a few miles on the bike, get them all professionally cleaned, rebuilt, and flow tested. Relatively cheap at about $18.00 each including O-rings and injector grease.
