Rocket won't fly.
L.W. Tischler
Standard Bore
3251 E. CR 411 may, Tx.76857
Fuel pump is not working no juice to it. went ahead and replaced fuel filter. Pumps when jumped from battery but ECM doesn't feed it. Fuse is good for Engine, wonder what else to check? can I get by with a switch to run pump? Ya think? I'm not too familiar with Tune Boy yet but when I hooked it up for diagnostics on the fuel, it said NO.
ALSO CURIOUS Has any one else had problems with the final output bearing on their rocket but me? That is the flimsiest cage I've ever seen on a bearing that size. I replaced it with a turbine engine bearing and have 5k on that and seems OK.
Check the wiring scemes in the manual for where your problem could originate.
I just looked at the manual and your fuel pump relay is where I'd start. Sounds like the relay isn't picking up.
