rocket turbo
roket
Standard Bore
Hi all I have just started putting together a turbo setup for my 05 rocket was wondering if there was any info out there regarding running the oil drain from the turbo can I use the scavenge pumps in the sump?appreciate any help cheers
If you can find a way to dump the drain into the sump area the the scavenger pump will send it back up into the tank and thru the system. When I get downstairs I will look at the block and see if there is a good place you could drill and add a pipe nipple to feed the sump. If I could get a look at where the oil outlet of the turbo is it would help a lot.
I don't have any photos but have pretty much copied the mc express setup could I use the front sump drain? Cheers
