Rocket is not a motorcycle one can ride in shorts
A1A Rider
Go big and go broke
Rocket 3 Storm GT 2025
So, rode in shorts and cooked my right leg. Yeap, that is the gist.
In the summer, can't ride in shorts or the sun will burn the knees to a crisp, in winter, when one can finally ride in daytime, it is the radiator fan output that broils the leg. I guess, you can do it on a highway, maybe a local road with a wind removing the heat... But if you get stuck in traffic somewhere, or a long traffic light, it will cook ya.
Maybe R version has better leg position in comparison to G, further from the radiator, but, who knows, maybe it is even worse. On G, I can kinda keep my right leg on the outmost peg position to help to move the leg from the directed hot air from the radiator, but it is possible that on R, it might, be in that position to receive the hot air cone, and moving a leg will not help ya. I don't know.
Another issue is the Competition Werkes exhaust, it is so short, even when the bike is stationary, can't really keep my leg on the ground anywhere, closer to the front wheel, the radiator gets me, closer to the rear wheel, the exhaust bites... Basically, no good position. You just take turns to bbq the leg in places where it is not yet as well done.
So, guys, no shorts on the Rocket.
Sounds about right...
I bought this kind of thick heatshield piece,
still easy to bend and cut
put it below the smaller OEM shields you have on rocket header(marked in red square) cut around the OEM shield shape, then make two holes in the alumimum shield so the OEM shield bolts can be fastened back.
Try this, it helped, should help you as well
i cut the pieces same size as
I bet you don't live in Florida. 😉
Yesterday we had 41C here (peak summer I have seen 48C here) ... I always ride with full Jeans, light weight summer jacket, gloves and a helmet.... I unfortunately bare the scars and have the titanium pins and screws in my body as a reminder.... Ride safe to ride again! Blessings and a blessed Christmast!
