Gents. My recommendation for what it's worth. Use any motorcycle specific full synthetic oil whether it be 5W-40, 10W-40, 15W-40 or 20W-50 etc etc depending on the ambient temp and riding mode you enjoy. Hot weather, 20W-50. Very cold, 5 or 10W-40 (Canada). Full synthetic.... yes simply because the viscosity doesn't break down in our engines as quickly as semi or non synthetic.
If you want to use non synthetic to save a buck, be ready to change your oil more often because that 20W-50 will rapidly become a 20W-20 as the viscosity is chopped up by the transmission gears.
Remember, simply put, the first set of numbers represents the viscosity of the oil in winter. That's what the W stands for. 5W-30 is thinner than 10W-30 at 0C. and will allow for easier starts in very cold weather. So, if you are regularly starting your vehicle in very cold weather, go thinner on the first set. The opposite is true. That's why Triumph gives a range. 10W-40 or 15W-50. I run 10W-40 Amsoil/Mobile or 5W-40 Shell Rotella T6 full synthetic in Canada (depends on what's cheapest)
The second set of numbers represents the viscosity of the oil once warmed to operation temp. 100C. Lower numbers represent a thinner oil. Use a higher number for severe use (high ambiant temps, pulling a trailer, sustained high speeds etc).
