Kendoville
Standard Bore
Zero
Hi, Guys ... Mate has a Rocket 3 classic that's been 'triked' and won't start. Was running OK before but won't now. No error codes show up on ECU and everything looks ok ... battery charged to 12.9v ... can you suggest anything?
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
It more than clicks .... it spins the engine but doesn't start .... the start button, etc seems ok ... from rainy & very cold Bonnybridge in Scotland ...
has it been sitting for a while?
might try a shot of starting fluid to see if that helps.
over here little critters likes to chew on the wires might take a look
gas could be old and it wont hit a lick
do u here the pump run for a couple seconds when u turn on ignition?
Kendoville
Standard Bore
Thread starter
Zero
Had the TuneECU diagnostic active on the system and it allows you to 'test' the fuel pump, which I've done and all seems ok .... and early on last week we tried the 'starter fluid' through the air filter but nothing happened. That was when we realised / discovered there was no spark at the plugs either.
TURBO200R4
TUCSON AZ
with a 12volt test light check coils for 12volts if it has 12volts then ***with ign on
on test light hook clamp to batt neg side and probe to the ground side of coil and see if it flashes when cranking (on each coil)
Kendoville
Standard Bore
Thread starter
Zero
Will try that later ....
Mr G
.060 Over
Bromley UK
2014 Triumph Rocket 3 Roadster
I know its been triked so the side stand may have been removed . Could it be to do with that , On the standard bike when side stand is down it wont start .
AdBlock Detected
I've Disabled AdBlock
