RoadVenture
.060 Over
- Joined
- Sep 18, 2007
- Messages
- 186
My RIII has the Rivco Risers put on by a previous owner. I'm not so sure I like them because the intruments are pushed out over the front of the gas tank up to the front edge of the gas cap. Well, they are on there and I don't have the stock risers so I guess I'm stuck with them. The DO raise the handlbars and bring them back to me a bit closer, which is good. But I wanted a little less stretch in my arms so I bought and am in the process of installing a set of CLASSIC handlebars. I want to go back to the OEM cable routing so I am going to get replacement clutch, throttle and brake lines.
This is what I have determined so far. Using the OEM cable/hose routing, Rivco Risers and the CLASSIC handlebars the cable lengths look like they need to be:
+3 1/2" for the clutch cable
+ 2 1/2" for the throttle cables
+ 2" for the upper portion of the brake hose
How does this seem to you? Has anyone else done this and have actual measurments for your replacement cables and hose?
Thanks!
Thanks!
