tdragger
Many years ago when tubeless tires were invented they had to design what was referred to as a safety rim. There was a ridge installed right behind the bead seat area of the rim. That’s why when you inflate the tire for the first time it pops up over the safety ridge. This is to help stop rapid deflation by trying to keep the tire beads attached to the rim when air is lost.
This is also why you need to “break” the bead loose from the rim when replacing the tire.
The RMA is stating that the bead seat area on the rim is different on bike rims and car rims. So, the bead on the car tire might not fit securely into the bead seat area on the bike rim.
That’s because the bead seats are often larger on car tires. Plus the bead taper is slightly different. Especially if the rim width is not as recommended for the tire installed.
What you need to do to be certain would be to measure the bead width of the tire and then measure the bead seat on the rim to make sure the bead will fit securely in the seat between the rim flange and the safety ridge. If it doesn’t fit…they bead will come loose with low air pressure.
I’ll measure the bead seat on my rim the next time I remove a tire. But, I’m pretty certain the bead is narrower on the bike tire and rim.
Yeah, in a few months you should be able to take that measurement. Unfortunately, I will not be able to also take that measurement as I have just replaced my Riken Raptor with a new one. It will be another 3+ years/29,000 miles before it's time to change it again.
