Boog
Traveling Story Teller
- Joined
- Oct 17, 2013
- Messages
- 8,501
- Location
- Dumfries, Virginia
- Ride
- 2014 R3T, RAMAIR, Full Viking Dual exhaust
Hello all ye learned masters of stopping.
My first questions is: What new calipers and brake lines will fit the ABS version of the R3T (2014) without needing fabrication?
Second questions: What do I need to know about doing this swap at home? I get the idea that ABS is a more serious/attention to detail evolution than standard brakes.
Recently, Brahma had the master cylinder and the right front OEM caliper rebuilt . I mentioned in another thread that the front brakes still feel mushy but after pumping the grip, they pressure up. I believe this is an indication of air in the line but I have failed to get it out if it is.
I have read many threads here and think maybe the Pretech Six Pot calipers are the way to go such as @Joesmoe and others have gone to. I want to go to steel braded lines to. Everything I have read tells me they help to pressure the calipers a split second faster because they do not expand like OEM lines do.
You know I am not known for waxing and polishing the bike and ride in every condition around. I am learning all about corrosion issues. Brahma is starting to need new parts anyway so I might as well go with the good stuff. He has eaten up much of my disposable income of late, but I do intend to keep him around to the end. With that said, is there a better or more cost effective means? Brembo is great on the 2020 bikes for sure but I think it is pricier.
Should I change the disk as well? It seems to be in good shape judging only by feel. I see quite a few of you have changed that too. @Paul Bryant has a good write up with his set up. And I see @1K9 and @Tripps and others have all had a go at upgrading calipers.
Keep in mind guys, I do not even qualify as a shade tree mechanic, (I don't even have a tree).
I am on the Pretech website now but am confused as to which caliper: I do not see any supporting ABS or for the R3T, they just have R3R listed. I have sent them a message.
I look forward to your sage advise...
