I haven't done any and my back tire is looking kinda grim at 7600. Then again the roads here are like 40 grit sandpaper. Front is still rocking about 3.5-4mm tread.
No choice this end only sold in pairs??? Another scam!! I've got a couple of fronts in the shed I hope to use 1 day, I purchased a rear chrome on ebay UK with 1mm of wear for?£60 so I can start using the fronts up
For those that do dyno runs, do you put the bike on the dyno and then change the tire after because of the stress on the tire or do you not worry about it?
Several tire manufacturers say that they won't warranty the tire after it is run on a dyno and some say not to use the tires after they are on a dyno. I was wondering if that was a thing that the manufactures say because you can put a lot of stress on a tire or someone could setup the bike wrong on the dyno. Or if this was not a real world concern.
Front and rear are both just about done on mine now, at 18,600 kms (clearly I'm not riding it properly !). On my last few bikes I found that both front and rear were wearing at the same rate (Dunlop Road Smarts).
