REAR DIFFENTIAL OIL
Triumph recommends a 75W-90 gear oil. I have been using Amsoil's Severe Gear 75W-90 oil since new. It's expensive but since you only use 4 oz at a time, it's cheap.
Amsoil recommends changing the oil every 100,000 miles in an automotive application but in a motorcycle and with only 4 oz in the sump, I change mine every summer. The first time you drop the oil, you will be amazed with the amount of contaminants that come out. That's why it should be changed often initially. You will find that the oil gets cleaner after a couple of changes.
VALVOLINE 75w-90 full synthetic
first time i was shocked the small amount that came out and very black since then it comes out like new but i change it every engine oil change (5000 miles)
just go easy on the bottom drain
thanks .
