Rack for trunk?
Not certain what a Wompus is, but I've successfully mounted trunk(s) to the Triumph sissy bar/luggage rack on my Roadster by not using the sissy bar. Used both the JCWhitney and Bestem trunks. The Bestems a little larger/nicer, IMO the JCW is easier to use.
If you plan to keep the passenger seat I know of no other provider than Triumph to make that happen. If you want a luggage rack in place of the passenger seat a lot of racks designed for 16" rear wheels will work. I.E. the rack from my '02 Victory is a perfect fit.
Hope this helps.
Armin
I had to modify my existing Triumph rack to add a GIVI mount . If you look below you will see that I made it to tilt so that I could access the bags.
I posted the pics to give you an idea of what to do and also I happen to be selling it. If you are interested, look in the classifieds.
Hope it helps.
Scott
I just received my HD trunk and plan on doing it up like this bike I found on the web. I will post pics of what I did when I get it done.
