DEcosse
If it's no Scottish it's CRAP!
.... but no fog lamps.
May have be a mod on the fog lamps because the switch doesn't work and they are on all the time.
I'm confused by what you have written - says no fog lamps but then all the time - do you mean you had modded because they weren't working off the switch and WERE on constant - however now not on at all?
If you modded, can you provide details of what was done please?
Was this a factory kit, or did someone retrofit these? (even when not direct from factory, the OEM kit comes with a harness including a relay that does NOT send current through the key-switch)
Well it might be, or could be the switch - just have to inspect and seeSo are you suggesting I look at the connector splices and see if the Brown & Blue/Yellow wires are open. maybe a poor splice or over heated?
Sorry, that does not compute - the aux lights ALREADY operate off a relay;Now he has to change to 35w back again or must install a relais
And the fuse will not blow because of 55W bulbs - the relay is supplied by Fuse 1 which is 15A - two 55W bulbs are less than 10A
