There's one more point I'd like to add here about spring rate and static sag. The rear springs on 2.5L Rockets are linear, thus the newton-meters per millimeter are set. Setting the static sag for 30% of the total travel limits the travel to 70% of the length. Setting the sag to 15% means 85% travel, 10% gets you 90% and so forth. The travel length is the key here, meaning with limited travel length the shock has to absorb and limit the compression of the spring before it bottoms out. The spring is not going to change how the shock feels under compression, only the total amount of travel available. The shorter the overall travel the greater the compression damping needs to be to prevent bottoming and the resulting ride is harsher. Since you gain nothing by setting sag to 30%, set the sag for 15% and back off the compression damping since more travel is available and less damping is required, thus the ride feels smoother. You can also back off the rebound damping so it recovers to the full travel length faster. You may find yourself balancing forces between pogo stick and hard tail but once you find the sweet spot the ride is as good as it's going to get with OEM equipment.
