Oil plugs, replacement bolts w magnets
cr0ft
Finland
Triumph Rocket III Touring 2010
Magnets sucking iron filings out of the engine is a good idea and many engines come with them stock, but they're often pretty weak.
So I figured for my next oil change, why not upgrade to some serious rare earth magnets? The only issue is finding the right sizes at http://www.drainplugmagnets.com/purchasebythreadsize.php
I actually haven't changed the oil on mine myself yet, partly because I'm lazy and partly because I prefer to have maintenance done for me for the stamps in the service book, but looking at http://www.worldoftriumph.com/trium...ck_01=&block_02=100053728-1-2&block_03=610510 it seems like the plugs are M14/1.5, so that's one bolt size down - two plugs in the sump.
That leaves the notoriously weak bolt in the final drive unit, and unfortunately the site doesn't list a size for that. Anyone know? It would also be a useful bit of info to have if or when it snaps.
http://www.worldoftriumph.com/trium...ck_01=&block_02=100053749-0-2&block_03=610510
Bikebandit's parts fiche often lists nut and bolt sizes
Unfortunately the same thing as with WorldOfTriumph - just says "plug, oil drain, magnetic". So it already should soak up filings, but uprating the magnet might be fun to do just for the hell of it, I thought.
Saw this in Daytona looks like what your looking for, maybe we should get some custom made for the final drive..;)
Yeah I was trying to see if they already had one that might fit, they have a bunch of sizes. Just not sure about the size of the final drive bolt.
The standard Triumph-labeled ones looks right for the sump - M14x1.5x16.
