OK, ran an ohm check but didn't write down the numbers, just checked to see if there was a constant increase in the sweep from min to max. the tps at the "rear" of the engine passed, the tps at the "front" dropped off about half way through the sweep. Checked it several times and I recall the number that it dropped off at was 19.xx. Bad component!!!
Here is my dilemma now. The Rocket manual shows the "primary" tps at the rear of the engine and the secondary at the front. Simple enough. It also states that they can be identified from each other by the length of the wire lead. The secondary has the longer lead. It also states that they do not interchange with each other, which I found to be true. While performing the ohm check, the "rear" tps rotated clockwise from low to high ohm, the "front" rotated counter-clockwise from low to high ohm. This make sense due to the fact that they both couple up to the same shaft, only at opposite ends.
Bike Bandit shows the diagram of the throttle bodies and associated components of the 2005 Rocket III (under "Throttles / Injectors and Fuel Rail"). The image and accompanying balloon numbers imply that the "long lead" item (item 2) is the primary tps. AND, if the diagram is properly proportioned, even shows the long & short lead difference.
Now I'm most likely to rely on the Service manual, which implies in a handful of places that the Primary tps is at the rear of the engine.
What would you guys/gals do, order the item that is shown toward the front of the throttle bodies and hope it's the right one, or order the one that states it is the "secondary tps"?
I think the Bike Bandit diagram has the two tps items labeled reversed (2 should be 4 and 4 should be 2).
Internet info shows the part T1245010 is the secondary TPS.
