I doubt you could do that bud they are all the same length and width. the height changes. I suspect even with the small one mounted like Duncan did will not fit under the claw. and if it did you would be stuffing the motor with hot air. IMO the longer runners like Duncan used on his first addition shown above reduce power output. If they did not then the OEM plumbing with the OEM air filter location would be better as it atleast has a chance of pulling cooler air. The problem with it is the air gets a chance to heat up under the tank so your back to square one. I see why he did it which was to rotate the filter to clear the attachment tabs for the base plate. He has since changed it some and removed the tabs like I did. I also plann on using a Outerwears prefilter to keep her dry. I use one on my SC bike and withthe filter out in the open you can still run her in a monsoon rain.
Thank you for your help and review Evil Mitch just do the job and send a new Tune ECU map for my beast that wil do that , I want to remember to all of you that my resources here in Argentina at the moment is limited I mean no big KN filter anywhere .....just this is what I found and payed like 50 usd for 4 filters for sure with time will have KN installed and with prefilters done, thank you guys for your help
Yes I can buy it from ebay but the problem here is the postal service delivery mostly they don t and then another issue is customs that s why at this moment we are having problems with everything here from parts, etc thank you for you help also.
By the way just went for a ride with the new map and tripples ....is all a new world just amazing
