No Power at Hella Plug
maurice
Tucson,AZ
2020 R3 GT
Have a dealer appointment. Service guy said that hella plug not designed for compressor, may blow a fuse. Once they get power, will see. Spares in bike.
Ygransom
Turbocharged
Surprise, AZ
08R3T
Did he mean not rated for a compressor in that Triumph used too small wire gauge or fuse? A Hella plug should take more current than a cigarette lighter plug
maurice
Tucson,AZ
2020 R3 GT
? Worse that can happen is replace fuse and don't do it. I love tests.😁
MrPix
.060 Over
Speedmaster 1200, Rocket 3 R 2500
BUT, the compressor you have (in the other thread) is 120W === 10A and the accessory fuse is 20A so it should not have blown
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
I would say the best thing that could happen is the fuse would burn out!
Other things like melting down the terminals at fuse box/melting wiring from fuse to rececptical or melting wire causing short to ground.
I would find out what amps that circuit is rated at and how many Amps your compressor Uses.
just a dumb ? would the compressor be overloadin the circuit?
maurice
Tucson,AZ
2020 R3 GT
Oh yeah, not liking idea of terminals melting down.
Grumpy Ole Codger
Slave to the Beast
Bognor Regis, West Sussex
2007 Rocket 111 Standard..ish
As with all motors, they have a high start up currrent and the stated current usage of the item by manufacturers has a tendancy only to relate to be the running current and not the start up current. Worth checking out the true current usage first. Reason why Mcb's and fuses have different ratings - A. B. C. D type (in UK) etc.. Most important thing is to make sure the cable size and it's current carrying capacity is correct for the load to be applied. Best working pracitse is to use the next cable size up to ensure cable is protected by the fuse/device.
maurice
Tucson,AZ
2020 R3 GT
Since this hella plug is being used only to fill tires when needed, starting motor and then plugging in solves problem doedn't it?
MrPix
.060 Over
the motor mentioned by Grumpy is the compressor motor, not the Rocket engine.
AdBlock Detected
I've Disabled AdBlock
