no horn or indicators
ade
Standard Bore
newcastle nsw aus
rocket 3 2007
I have rocket 3, and all was working fine this morning, but went to indicate to turn an no green flasher on cluster an no orange indicator, tried horn no horn so thought ok must be fuse?
arrived at my destination, switched off engine and switched back on the cluster light up showing the led's are working, checked fuses nothin has blown, ??? what next pls help
Your flasher unit may be toast. You can also look for a common ground problem. I'd recommend first pull the flasher unit and clean the stabs and try it. Then work back from there. You can download a free manual by looking up any post by Bishop. He has a signature that includes the link to the pdf. Get that and we can work the problem.
You can try jiggling the wires from the ignition switch and see if they start working. If they do, get a new ignition switch and an Eastern Beaver relay kit (or make one up). The switch carries too many amps for long term use.
I had the same problem with the indicator and horn not working. It started after I washed the bike and I discovered a blown fuse which was replaced. But it still continued to blow fuses. I found a bent terminal in the rear indicator socket and possible shorting out.
I never really got to the bottom of it,but it hasnt been a problem since.
ok so bike is in my garage and i have done the wiggling of wires at handle bars (left hand side for the indicators), and nothing at that point but then when i turned the handle bars to the right woh the horn the indicators work so yes its wiring and followed it down to the black cover just between fuel tank and fokes, who has the wiring diagram for that are thanks, who is bishop?
thanks for the help
