No electrics
In the early years 1960s ----> we dealt with lord lucas here we go again ;>(
Not sure. I had a 2005 standard and never had an issue. Of course it probably had a little different set-up. I just hope when I do take mine down again I find a problem in the harness that I can see.
I took my bike apart and found the same white/blue wire fried primarily on the female side. I was able to remove the wire from the harness, but since the holder was melted I cut the wire out and soldered a new wire direct. I'm thinking since I run with my lights on bright with running lights during the daylight hours may have caused high constant current. I also think running the wire direct my lower the resistance.
This Web site is a life saver. Thanks to everyone who shares.
Facing same issue....Did it solved the problem...I am planning to replace the connector this weekend..
