warp9.9
Pocałuj mnie w dupę
Mark, yes the Gi pro opens the secondaries when you select a gear. Looks like 100% to me but someone else will have to varify that.
As far as the speed limiter, it says it gets rid of it but I can't say for sure as I don't have gps to accuratly check mph.
Like I said I am not totally sure but if the gig pro makes it think its in a different gear and the tune in that gear does not open the secondaries to 100% till after 4000 rpm wouldn't the gigpro mimic the same function NM ? I was also thinking if the say 4th gear actually has now speed limiter wouldn't you still be limited by the rpm/rev limiter? I noticed this on my bike before I got tune boy I had a classic which was set to 125mph max and I good do more in 4th then 5th but I still pegged the rev limiter at about 140 ( on the standard tune boy tunes is 6300)if memory serves me right. Like I said Mark get several opinions don't just trust me NM knows me and he will tell you I am a honest guy but I can still make mistakes so ask some other captains also! Its easy to check the theroy just put her in furth and run her up and find the rev limiter and see how fast your going it does not matter if your speedo is off we canalways calculate the speed by adding the 6%-7% its off to it. But make sure you set up is safe running them speeds is not the safest action nor legal so go where there are no cops.
