After a year or so and two unsuccessful trips to the dealer, I finally decided to tackle this idle problem myself, and solved it in about 30 minutes.
I took a T25 hex bit and loosened the primary TPS. With the bike running kind of rough, idling at 3,000 RPM, I moved the TPS back and forth. I discovered that the TPS is nothing more than an adjustable main jet. Turn it one way, you get too much fuel.. turn it the other way, you run too lean. So, by ear and feel, I gently moved the TPS until the my bike was running really smooth.. Still idling at 3,000 RPM, but running very smooth.
Then, there's a 7 MM nut on what I suppose is a solenoid to control idle and for cold starts. I turned it in, bringing the idle down to about 800 RPM. Then took the bike for a test ride. It ran great!!! Except for a small hesitation at about 1200 RPM. So, I raised the idle up just a bit to about 850-900 RPM. (I was suspecting low idle, or the 'accelerator pump' feature in my PCIII.) After adjusting the idle up just a bit, the hesitation was gone! I then let the bike do a '12 minute' tune.
This will be the second day riding the bike to work and back ( 70 mile round trip ) and the bike drops right back down to idle every time and runs probably smoother than she ever has! I will keep tabs on it, of course, but wow!
