Trust issues, it’s why so many of us will not go to a dealer, these bikes are good, everything has to be done correctly or they will expose the person that did the work. Very small tolerances and must be right, everything
I’m just looking to see if it’s common to remove the muffler for tire replacement , There is the chance the tech forgot to bolt the muffler back on after sliding the end on the catalytic box. Luckily no injuries to me except in the wallet !
I always remove muffler prior to a reat tire change - now at 11 rear tires and counting . . .
From the bevel box side.
Because of occassional can dragging, I had the stainless tube between the collector & can modified to tuck the can up and inboard to the rear axle nut.
Solved the clearance issue, but now the can needs to be removed to access the axle nut.
