Motorcycle camper trailers
Am not rich bought used 2000 model Bunkhouse XL but is an extremely good shape, I took the frame apart sanded and painted went through wiring harness checked it all out and ran an extra ground reinstalled everything have it set up in the shop looks in good shape except for some stains were they had put it up wet and did not take it apart and dry it out soon enough. I called manufacturer they said what ever I did do not use bleach looks like the stains are permanent unless somebody has an idea
I have an idea Uncle Jesse,
Make sure you put the thing back together and use it, dont let it sit in your building for 5 years like your music equipment
It has already been sanded and painted and re-assemble also did the wiring harness added another ground wire they were using all frame ground with pop rivets not good and is now setting in the back set up airing out DeAnna said she's going to forbreez it is hard to believe we both were back there laying on the bed had all kinds of room
Big kids with new toy
no, lupe, he is, im not!!!!!!
Re: Stains
Hi Uncle J
Sounds like a problem you got there If it is on the canvass... it sounds Like Black Mould resulting form the unit being closed up Wet, worse thing you can do unfortunatly.. as it can also cause the canvass to Rot and then Tear easily But hopfully its not that bad...
The only trick I know is to rub the stain with <Sponge Rubber> but not a piece of old crap from a Garbage Tip you don't wanna make more marks, you will need to do this on a clean board for support. It was passed onto me by a Canvass upholsterer...
Never tried it so I Cant Guarantee it will work..also Black Mould stains will only come out with the >"Dont Use"< Bleach I think so you could be stuck with it.
Sorry cant be of more help on that one.
Hi Uncle J
Jesse ... try this stuff if this don't get it out you are going to need a new one
http://www.scoe10x.com
Thanks for all the recommendations we were looking at the stain it appears, what ever was used to clean canvas took the green tent and turned it silver does not appear to be mold but when you look from the inside out it just looks dark got outside with shop lights and noticed the silver color does not appear to have any damage to the canvas. Inside it has got a rubberized coating kind of reminds me of the old rubber rain suits put water to it does not '''leak''' At first it just had a smell like a suitcase that has been closed up in storage after a couple of days of airing out it is fine were looking at using it this weekend if nothing else just running over to one of the local state parks
Not Taking Life Too Seriously
And christen the Mattress I hope
Do you think someone has dropped Silver Paint on it by accident maybe ?
