buddazero
.060 Over
New York City
Triumph Rocket 3 Roadster 2018
Hey beautiful people! Need some help if at all possible.
I'm looking for the Tail Light / 12V Switched Power Source", which I suspect are the same.
I have the Scorpio 900 Alarm System, so far I got the positive and negative wires connected, and next I need to connect another wire to the 12V Switched Power Source [aka Tail Light].
Word for word these are instructions for the third wire:
"White Wire with Quick Connector: Install this wire to a 12 volt switched source using the provided
Quick Connector. Remove the cap on the open end of the Quick Connector attached to the white
wire of the installation harness. Insert the switched power wire of the vehicle into the slot in the cap.
Tighten the cap back on to the Quick Connector.
Locate the 12 volt switched wire source on your vehicle. The most common applications are
the tail light power wire (not the brake light) or the license plate light power wire. Do not attach
the white wire to any LED light sources, as LED lights may operate at a lower voltage."
Does this make sense, I suspect the tail light is either around the right or left side panel. Please and thank you for your help
Best,
Budda
