Just my observation
Technically it wasn't my dealer. I was just talking to some members awhile back that had ran a CT and both had splines that was worn prematurely by running a CT. I was just stating what I was told. One of the members said the splines on his bike was worn to a "point" and had good bit of slack. They changed the axle to a new one and the slack was gone. He used a MT after that.
NOW thats funny PETE riding in an upright position and never turning and running on the sidewall ?
IF you dont lube the splines correctly with the proper lube your going to damage the splines
Regarding a darkside tire running up on the sidewall.....I will not do a DS tire, but there are such tires that have some tread that wraps up the sidewall a decent amount...that might be worth looking for if you are going to go that way.
Have been running a 225 car tyre on mine for more than 70,000km now. I do this because we have a sidecar attached and it gives a better contact patch on the road etc. I lube the splines regularly as I once owned a BMWK100 and did a crown pinion bearing in a big way 6 hours from home on a Friday night. So far everything is going well.
