Update - apparent paranoia & operator error
OK, all appears well at this point.
I redid the "12 minute" tune.
Timeline and facts:
1. Water level cold is at MIN (I had filled it to MAX last week - looked
low and made sense at the time ;^)
2. Started bike. Idles very well.
3. Water level rises to 3/4 full (half way between MAX and overflow)
4. 8 minutes for fan to kick in.
5. Water level lowers to MAX and fan stops.
6. Water level slowly rises to same 3/4 full level; fan kicks in.
7. 5 and 6 repeat and all appears normal.
8. Waited 15 minutes. All is well - no overflow or apparent overheating
occured.
9. Waited 10 minutes.
10. Coolant level returned to 3mm below MAX.
Conclusion: Either I had overfilled coolant last week or in fact the
engine had overheated last night while it was re-learning the new
triple K&N airflow pattern.
Lessons learned: Check coolant level after warming up engine and at least one full fan cycle to let radiator and reservoir quiesce to steady state
and ensure cycle is upright. DO NOT OVERFILL RESERVOIR.
Thanks for everything!
Now if it would only stop raining so I could take the beast on a new
& improved mods maiden voyage and see what all the fuss is about 8)
