Idol and backfirng problem with jardines and trip k and n
preed0814
I just got my 2013 R3T back from my mechanic. He installed the Jardines, triple k and n's, and tune 20366 thru tune ecu. Sounds great. I'm impressed with the sound and performance and the job my mechanic did. Problem is- it rolls and surges at idol and backfires thru exhaust upon 3/4 deceleration. As soon as i can get the money, which will not be for a while as i have a baby coming in 4 weeks, i will get PCV with AT. I'm going to take it back to my mechanic but wanted to know if someone has some imput as to what i can do to fix this problem. Thanks!
Save yourself the money the PCV + AT is Clinch to install just PM me your e-mail adress (Please include your forum name) and I'll send you a map I created for the PCV + AT that will make her purrrrr
DO you have the cable for the tuneecu?
Or will your mechanic load another tune for you?
If so I would try that until you can get the PC/AT
I have another tune based on 20366 that I got from Dennis here on the site. He and I both used it before getting our PC/AT...
Might be worth a shot. Also if you do not have a cable I would suggest you spend the $15 and buy one from Ebay or some where so you have it. If you Tinker at all you will need one.
  • Gieseking R3 FINALa.hex
Hey guys. Thanks for the response. I am going to order the PCV-at now. I came this far, we'll make it work.
I forgot to say inthat email I just sent you with the PCV map that it would be a good Idea to load the TuneECU map that bonecarver put in the previous post it will fix your ignition retard and other related things the PCV +AT only looks after the Fueling it is nessasary to do both to get best out of your bike as I said don't hesitate to ask ? you have my e-mail now:)
You won't be sorry... but do be careful until you get use to the new bike again after you get everything together. Hanso's fuel map will make a huge difference in your bike.
Hi Hanso
This might be a stupid question..but if you pull the battery off does it effect the PC or
any of the setup associated with it..just curious really ;)
Ray
