fastfun
Regarding widebands, you truly get what you pay for. I like the innovative brand products for simplicity of use, but, they're not necessarily the most accurate despite all their claims.
Per cylinder logging is fantastic if you can pull it off, but largely not required as long as compression is even, injectors flow closely, and the air flow is even to each cylinder. On a twin though, I would definitely do a perfect by cylinder map as they are much more temperamental and the differences in temperature of each jug can make a big difference.
Update (18.00 European/Greenwich timetable):
Sooow, after a hard day's laptopworking we got still at a sh.... mapping. Especially everytime at the same low rpm range/ throttlemoment
What did we do just now : got out from the 2004 Rlll its map , which was running fine in that bike.
Next, saved it as a TuneEcumap.
Next, the Roadster didn't like this map : "not compatible".
Next, got out the OEM Roadstermap and saved it in TuneEcu, copied everything suchas fueltables, the F and L ones and also ignition and paste these into the OEMroadstermap, wrote them to the ECU.
Now, those settings were accepted.No issues with that.(PcV set to O ).
Although this 'new'map is a copy of the 2004 map, this map is running way off target.
If it does the matter,question too is, does the OEM MAPsensor still be connected with its connectorplug?If I can recall correctly, TTS removed the MAP of the 2004 bike.
By the way, as I did in the 2004 one and still do in this Roadster, I use the Siemens deka ones, 80lb/hr
Does the Mapsensor still be in connecting with its connectorplug ?
