HELP! Wide Band O2 Calibration: Full grip gives 100% TPS engine off, but only ~94% under load. Anyone have a WOT log?
bcar00
.060 Over
Rocket 3 GT
I’m tuning my Rocket 3 GT with a wideband O₂ sensor. I’ve improved the part-throttle fueling and around-town manners. Now that I’m working on WOT, I’m trying to figure out why I'm not getting 100% TPS or >95kPa MAP. The 100% grip column in my ETV tables is set to 100% throttle throughout the RPM range.
I logged acceleration pulls with my Wideband software, then verified with TuneECU. Here’s what I see:
  • Key on, engine off: With the grip against the stop, TuneECU shows 84.7% Twist Grip Position and 100% Throttle Position (TPS). Both throttle-position channels read 100%. (see pic)
  • Full Power Run (Grip fully twisted): The grip reaches the same 84.7% raw reading, but the highest actual TPS I saw across the pulls was about 94%. TPS falls as RPM rises even though I’m holding the grip against the stop.
  • Manifold pressure: Average MAP across the three channels stays below 95 kPa. You'd expect 98-99kPa in a well designed engine. For reference, my engine-off MAP reading was 102 kPa.
What I don’t know is whether the ECU treats that 84.7% grip reading as full rider demand under load, or whether some other limit is reducing throttle opening. I’ve attached the plots. For readability, I scaled the grip trace only so that 84.7% raw displays as 100%. The TPS trace is exactly as TuneECU logged it.
Could anyone with a Rocket 3 check what TuneECU shows for Twist Grip Position and TPS with the key on, engine off, and the grip against the stop? That would help me tell whether 84.7% is typical or specific to my bike.
And if anyone has a dyno log showing actual TPS and MAP versus RPM at full grip, I’d appreciate the comparison.
