Hello to All Rocket Owners from cold South Australia /Adelaide /
Hello bro yes i have stadard pipes with cat delete ram air from England .gipro att wth gears have display have use tune ecu map zwuggi from Germany base on dyno tune set up have more induction noise .had tor triumph pipes b4 but with cat delete sound to lound .may consider to buy power comander and dyno tune best regards Rob.
All good i did download tune ecu map zwuggi from germany base on some sort dyno tune .run ok just drink more fuel much more my mods are just basic upgrade intake man with ram air and exhaust with cat delete have gippro atr have masive intake noise when i open gas .regards Rob
Rob of course mods equate to more fuel usage the only way to get around that is to have the bike on a dyno and tweak the cruise areas in for mileage as you will go right by them Throttle positions when your getting on her. You can also install something like the Carpenter kit which pretty much retains good fuel mileage in the lower rpm areas and then when the cams kit in your using the full 240 HP that is available in the high rpm end.
Thanks dyno tune here cost 550$ may have 2. cheerse.
