Have a look and comment ...
Radek
Standard Bore
Rocket III Roadster
Hi,
finally I had some time and downloaded the map from PCV, I own '13 Roadster with 3xK&N, secondaries removed, stock exhaus, this is how the bike was config by previous owner.
Can you look on the PCV map attached, it looks strange IMO.
I compared my map TRIIIR_ZeroMap with the map from Dynojet M21-003-005 to make the bike less nervous at the low throttle, it worked out, but still majority of my new map is like original TRIIIR_ZeroMap.
Last but not least what map for PCV you recommend as a starting point for my bike config?
(I changed the extention to .txt to be able to attach file, please change it back to .pvm to see the map in PCV soft)
THX
  • TRIIIR_ZeroMap.txt
