GPS Failing?
It has everything to do with the light since the bike only knows what gear it's in after the GiPro tells it. The GPS sends it's signal not to the ECM any longer, but to the GiPro. The GiPro now tells the ECM what gear it's in so that the programmed tune for only 4th and 5th gears are used. It also tells the ECM when it's in neutral so that the neutral fuel map is used and the light is turned on.
The GPS was out of sync by about half a gear and the relearning procedure aligned it all back up again ..... it's fixed and working perfectly again.
I do love my GI pro it is so nice to be running down the interstate and look down and it tells me I'm in fifth gear, when you think you should have a another gear. Always remember nobody's perfect but some of us are closer than others.
It has a two year warranty, if it doesn't work send it back.
Yep, all the way to:
Healtech Electronics LTD
Bekes, Morigz Zsigmond U. 28.
5630
Hungary
They were cool in the email I sent them several weeks ago but all the way to Hungary for repair, no thanks. I'm done with GiPro, I'm going to do the resistor mod.
Hey HellFire,
I've got the bike tore apart and the wire for the neutral light does not go through the GiPro. I bet your not off the hook for your neutral light problems.
