JohnnyCanuck
Finally got the Gi Pro in and decided to celebrate my birthday by doing the install!
Have it all set up except for the black wire to the ground and the red wire to the power. Here is the issue:
I want to avoid connecting the Gi Pro to the battery b/c I often take the battery off to put it on the battery tender. I connected the Gi Pro ground to the negative terminal and screwed it tight and unscrewed it a few times today and noticed it is shedding all of the copper wire. Pretty soon - there isn't going to be any copper wire left! The other option appears to be connecting it to the chassis ground. Has anyone gone this route and can they tell me where it is and how to connect it to chassis ground?
Next question: I would also prefer to connect the Gipro red wire to the fuse box using the red wire tap connector rather than connecting it to the battery. How do you use this connector and how do you install it? Has anyone done this rather than hooking it up to the battery? Thanks as always - very excited about getting it up and running!(also took off the bear claw and raised the fuel tank for the 1st time - super stoked!!!)
