Frustrated update
rainman
Seabee can do
niota tn
06 classic 2012 victory xr
Well finally got the dam thing back in put the gas tank back on and tried to start it no fkiing go everything seemed u can here the fuel pump run all it does is just turn over and over and over :banghead::banghead:
I did nothing to the engine checked all fuses they were good so now I need help
Did you have the fuel tank completely off?
Yes but I put everything back on as it came off and it ran good before I started working on it all I did was put the new heated grips on and the sir box which it should still start without the air box on right
If the tank was completely off, that means disconnection of the fuel lines.
The advice I received in that situation was to cycle the fuel pump multiple times by turning on the key waiting, turning it off without starting. If you're not throwing any codes, the ECU thinks everything is kosher, and with fuel, I would expect it to start. A little ether in the air intake would verify spark.
Finally got the bike running again thanks to warp aka Scott but now my heated grips and headlight don't work :banghead::banghead::banghead::banghead::banghead:
