atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 4,181
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
So at the risk of getting this thread back on trackWhat is the conclusion? I have been able to ride with no hands on every bike I've ridden except the R3. On my Rocket it is simply impossible. Other than pipes the bike is completely stock, no bags no nothin'
Cheers
Jthree
two things can cause this..... the crown in the road..... or if your head bearing is not properly adjusted.
Some Captains have reported this issue after having the front dresser (crash) bars installed. Somehow the frame gets out of alignment if you are not careful.
Perhaps you should loosen the front motor mount, turn the handlebars one way and re-tighten the motor mount to the correct torque specs. If it gets better then you're done. If it gets worse, try again but turn the bars the other direction.
I'm a believer in doing things simple to complex. Check headstock bearing adjustment, check wheel alignment (this validates frame alignment as well) and then check tire condition (both). Take a soft mallet and tap both front brake calipers and then get up to speed and see if the pull is still there. Then do the loosen bolts and re-tighten type stuff. But you need to validate each option before moving to the next to see if a change occurs so you can eliminate as you go. Doing a wad of changes and it's worse isn't a good scientific methodology.
